Dpit V4 - FinalVersion
www.dpit2.de
Scheint noch nicht gepostet zu sein doch durchaus interessant bestimmt für den ein oder anderen!
Dear DPIT users,
this is the complete list of changes for from V3 to V4.
v4.00.00b
(FIXED)
  • PlantVolume: Point Stretch bug fixed
  • PlantVolume: not working with deformers fixed
  • PlantWind: “only splines” crash fixed
  • DPInstantTree: disappearing branches fixed
  • DPInstantTree: point stretch bug fixed
  • Fluids: (vorticity & fluid) particles injection wrong translation fixed
  • Fluids: Wrong alignments for particles fixed
  • Fluids: Memory Leak from “unkilled” FluidParticles fixed
  • Fluids: Boundary turbulent behavior improved
  • Fluids: When a channel was cached but it wasn´t there then it crashed
  • Fluids: Force injection bug fixed
  • FluidParticles: attach object crashed for rendering
  • Fluid Smoke Shader: Contrast bug. 100% meant “no contrast change”.
    Now 0% means no change. Old scenes must be adapted!
  • Fluid Smoke Shader: Smoke Shader Use custom shadown bug fixed
  • Fluid Smoke Shader: Casting shadows bug fixed
  • Fluid Smoke Shader: Receiving shadows bug fixed
  • SimpleParticles: Polygon Selection bug fixed
(CHANGES & ADDITIONS)
  • SimpleParticles: Motion Blur support added
  • SimpleParticles: Polygon modes can now use a channel shader for emission location control
  • SimpleParticles: Active object is now linked directly if appropriate
  • SimpleParticles: Object Translation taken into account for collisions
  • Atmosphere: shader intensity added
  • PlantVolume: now uses a link field instead of a child
  • Fluids: advection steps now support Multiprocessors
  • Fluids: Solver option added
    o Natural Gradient is the more natural but slower solver
    o Gauss-Seidel is a relax solver. It´s faster especially at higher grid sizes, but the quality is lower.
  • Fluids: RAMtoDisk Caching added (allows to write the current RAM cache to Disk)
  • Fluids: Cache Frame (this allows to cache only the current frame. Good to “freeze” the current fluid state. Useful for still renderings).
  • Fluids: Some internal Fluids improvements
  • Fluids: File Format changes
  • Fluids: Added Flowmaps. This adds rich details to lower grid sizes.
  • Fluids: internal boundary update changes
  • Fluids: Core calculation changes
  • Fluid Slaves: interface changes
  • Fluid Slaves: Wind noise options added
  • Fluid Slaves: Smoke, Heat, Pressure and Wind can now be injected in world space. This makes the animation more scalable. So the low-res and high-res renderings will match much closer with this option activated.
  • Fluid Smoke Shader: 35 Smoke Shader presets added
  • Fluid Smoke Shader: Shading Map renamed to Light Map
  • Fluid Smoke Shader: Smoke Shader Light Map calculation now supports Multiprocessors
  • Fluid Smoke Shader: changed default values
  • Fluid Smoke Shader: Light Map “Proportional” option added
  • Fluid Smoke Shader: Shadow Transparency support
  • Fluid Smoke Shader: Reflection, Refraction, Transparency support
  • Fluid Smoke Shader: Shadow Density added
  • Fluid Smoke Shader: Added Noise Density
  • Fluid Smoke Shader: Noise Density can now be based on fluid velocity magnitude
  • Fluid Smoke Shader: Noise can now be taken into account for selfshadowing
  • Fluid Smoke Shader: when using “wind velocity” density base for smoke and heat, the max. speed is now calculated automatically.
  • Fluid Smoke Shader: Added Flowmaps support for noises. There must be a flow map and a velocity field present (either on-the-fly or cached) to use this feature!
  • DirtyTag: icon changed
  • Global: German Strings Updated
  • Global: Final interface changes
v3.99.99
(FIXED)
  • Extruder and ExtruderDeformer have wrong translations
  • SimpleParticles forget the last point/poly for the emission
  • SimpleParticles 0-Scale bug
  • Fluid Mesh didn´t work correctly when sensei was offset
  • New Demo cycle
  • Massive Smoke/Fire rendering speed up by Shading Maps
  • General renderspeed optimised
  • Hit Step added to Smoke/Fire Shader
  • Fluid First Frame handling improved. This should be much faster now
  • German Strings added
  • FluidParticles can now also be created directly by the Fluid Slaves
  • Clouds Material removed (It was only an experimental element)
  • General interface changes
v3.99.98
(FIXED)
  • Create Fluid Setup Crash on MAC
  • 4d particle modifiers crash in R10 when used in a “Forces” include list (Fluids, Particles…)
  • Waverine “RMultifractal” noise produces artefacts with octaves >2.
  • Collision tag collisions when source object rotates (in SimpleParticles for examples) doesn´t work correctly.
  • Fluid Shadows bug
  • CloneDummy doesn´t produce a box and doesn´t work with hierarchyInstances therefore
  • Collision Tag only collides against polygon normal direction
  • Sky and Atmosphere shaders have no interface in the MM
  • MountMonkey stability increased
  • Fluids: Caching bugs fixed
  • Improved Fluids redrawing
  • Smoke/Fire shader internal improvements and several fixes
  • Fluids Display improvements
  • Improved slave emitter shape detection
  • Fluids: Cache to Disk added
  • Fluids: Caching of Heat & Smoke now possible
  • Fluids: RAM Cache can now be used for rendering
  • Smoke & Fire Shader does now show the heat channel in the preview
  • Atmosphere now has a “ground offset” to shift the ground point
  • R10 specific version now added
v3.99.97
  • Advanced Fluid Engine for gaseous phenomena
  • Massive internal code changes for PlantVolume
  • PlantVolume Distance effects & More
  • Hair engine
  • PhysicalSky & Atmosphere Shaders
  • SimpleParticles particle system
  • Landscapist Rewritten
  • MultiToolBrush (MTB)
  • Transplant MTB support & Grey-value based placement
  • MultiVariance: Interface improvements
  • MultiVariance: Huge speed up!
  • MultiVariance: Added new modes
  • PlantLength: Fixed all bugs - multisegment spline support
  • Transplant: Color tab added - Place by Grey value here
  • Transplant: Backface culled placement added
  • Transplant: New placement options added
  • CollisionTag: Added Spawning support - All spawning features are defined here as they happen when colliding. If you don´t define a spawning emitter, the emitter the colliding particles come from will generate the spawned particles. Using a different one allows to use different dynamics, color, objects etc..
  • Leaf Object: Changed the bending algorithm
  • Leaf Object: Keep Length added
  • Extruder closed polygons bug
  • DPIT Menu added
  • New Converter Object
(Removed)
  • SplineConverter
  • NatureLibrary
  • DPIT R1 Object
  • DPIT Master
  • TangentTool
